phone username and PINs
Answered Question
Jun 10th, 2008
When setting up a phone with a UC520 bases system I see there are options for a PIN as well as a username and password. What are these used for? Will the phone work without them?
Diego
Correct Answer by Brandon Buffin about 9 years 1 month ago
CME IP address. Yes, this is linked to CUE. Users can add/change notification devices, etc.
Hope this helps.
Brandon
Overall Rating: 5 (1 ratings)
Brandon Buffin Tue, 06/10/2008 - 07:39
  • Purple, 4500 points or more
Diego,
The username/password is setup so that users can access the GUI to add/update speed dials, etc. The PIN is setup to allow users to override call-blocking patterns if configured. The phone can function without either of these.
Hope this helps. If so, please rate the post.
Brandon
DIEGO ALONSO Tue, 06/10/2008 - 07:54
What IP do they use for the GUI? Phone IP or CME IP? Also, any link to CUE? Or does that use seperate user/pwd?
Diego
Correct Answer
Brandon Buffin Tue, 06/10/2008 - 09:31
Hope this helps.
Brandon
