Custom SoftKey Dial
Jun 10th, 2008
I am using the CiscoIPPhoneMenu object for a list of people. I want to use the custom soft key to dial the persons number directly. It works if I hardcode the number but how can I make the "Dial:xxxx" relative to the person chosen from the list? (Eg. Dial:1234 or Dial:5678 depending on the selected item)
I know I should be using CiscoIPPhoneDirectory, but again I run into a limitation - I cannot add a custom softkey that calls a URL (.asp) with a parameter relative to the person chosen on the list (eg. myasp.asp?name=John). I want to show details for each individual on a list, if chosen.
Either object is ok with me - any suggestions?
pklos Thu, 06/12/2008 - 02:22
Use SoftKey:Select for SoftKey and define URL as Dial:XXXX.
EulessMan Fri, 06/13/2008 - 09:37
The problem is I need to get the selected item and call URL on another SoftKey.
Do you have any solution for that?
Thanks in advance
