CME off-hook dial
Jun 10th, 2008
I have this scenario:
Analog Phone----VG224----2851CME----IP Phone
I need the analog phone to dial a CME ephone-dn as soon as it goes off-hook. VG224 registers thourh SCCP with CME and I get a dial tone on the analog phone, but I want that phone to dail an extension when it goes off-hook.
I've read that with CCM you configure a blank pattern and assign that pattern to a CSS so when it goes off-hook it will dial the masked number. But how do I do this in CME since CSS don't apply?
gpulos Thu, 06/12/2008 - 10:46
  • Blue, 1500 points or more
In short, Yes.
You can use SCCP controlled FXS/Analog PLAR on the vg224 to accomplish what you need.
Please see the following link for more info on SCCP FXS PLAR:
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t2/ht1vg224.html#wp1299823
See the following link, from same document, on PLAR configuration for your SCCP controlled vg224 FXS:
http://www.cisco.com/en/US/docs/ios/12_4t/12_4t2/ht1vg224.html#wp1291125
chris.fortner Tue, 06/17/2008 - 09:31
On the CME router under the dial-peer for the analog VG224 port configure the plar command to send the call to the apporpriate destination. IE:
dial-peer voice 1 voip
connection-plar 4300 (version dependant)
