How to remove virtual dial-peer that created during CM SRST fallback
Answered Question
Jun 10th, 2008
Hi all, is it anyway to remove the virtual pots dial-peer below, that created during SRST fallback using CME. Tried to use 'no dial-peer voice xxx pots', but is not working.
SINPBGW01#sh dial-peer voice summ
dial-peer hunt 0
AD PRE PASS OUT
TAG TYPE MIN OPER PREFIX DEST-PATTERN FER THRU SESS-TARGET STAT
PORT
1 pots up up .T 0 up
0/0/0:15
300 voip up up 8679 0 syst ipv4:172.23.19.3
100 voip up up 86.. 0 syst ipv4:172.23.17.84
200 voip up up 86.. 0 syst ipv4:172.23.17.85
20008 pots up down 64198640$ 0
20010 pots up down 64198625$ 0
20012 pots up down 64198613$ 0
20014 pots up down 64198629$ 0
20016 pots up down 64198615$ 0
20018 pots up down 64198619$ 0
20020 pots up down 64198648$ 0
20022 pots up down 64198685$ 0
20024 pots up down 64198646$ 0
20026 pots up down 64198691$ 0
20028 pots up down 64198610$ 0
20030 pots up down 64198656$ 0
20032 pots up down 64198681$ 0
20034 pots up down 64198663$ 0
20036 pots up down 64198643$ 0
20038 pots up down 64198614$ 0
20040 pots up down 64198617$ 0
20042 pots up down 64198603$ 0
20044 pots up down 64198686$ 0
Correct Answer by gpulos about 8 years 10 months ago
You can't remove the virtual DPs manually.
A reset of the router should remove them until the next time SRST kicks in and has to rebuild them.
Overall Rating: 5 (1 ratings)
Correct Answer
gpulos Fri, 06/13/2008 - 02:45
  • Blue, 1500 points or more
ethangwee Sun, 06/15/2008 - 22:18
Thanks, it works, virtual dial-peer remove after the router rebooted.
