Signal Strength -86dB . Is it good?
Jun 10th, 2008
  • Silver, 250 points or more
I am trying to find if our new installation between Cisco 130 Bridges is good or not . Not able to find any documentation to read parameters . Can someone help?
Following is the ouput from the bridge:show dot11 ass all
Address : 001b.2a30.1460 Name : Calgary
IP Address : 192.168.100.99 Interface : Dot11Radio 0
Device : 11g-bridge Software Version : 12.3
CCX Version : NONE
State : Assoc Parent : self
SSID : Calgary VLAN : 0
Hops to Infra : 1 Association Id : 3
Clients Associated: 1 Repeaters associated: 0
Tunnel Address : 0.0.0.0
Key Mgmt type : NONE Encryption : WEP
Current Rate : 6.0 Capability : WMM ShortHdr ShortSlot
Supported Rates : 1.0 2.0 5.5 6.0 9.0 11.0 12.0 18.0 24.0 36.0 48.0 54.0
Voice Rates : disabled
Signal Strength : -86 dBm Connected for : 241 seconds
Signal to Noise : 14 dBm Activity Timeout : 29 seconds
Power-save : Off Last Activity : 1 seconds ago
Apsd DE AC(s) : NONE
Packets Input : 495 Packets Output : 1061
Bytes Input : 49678 Bytes Output : 105053
Duplicates Rcvd : 0 Data Retries : 375
Decrypt Failed : 0 RTS Retries : 51
MIC Failed : 0 MIC Missing : 0
Packets Redirected: 0 Redirect Filtered: 0
Scott Fella Tue, 06/10/2008 - 10:53
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
I think is all depends on what traffic you are trying to send accross. -86dbm isn't usually that great of a singnal to many. If you take a look at:
You can see your data rate is at 6.0 mbps.
singhsaju Tue, 06/10/2008 - 12:04
Thanks for the reply fella5.
So how can i improve the Signal Strength?
Any ideas.
singhsaju Tue, 06/10/2008 - 12:05
Any ideas.
Scott Fella Tue, 06/10/2008 - 12:15
  • Hall of Fame,
    2017 Wireless
There are a couple of things. Channel selection might help if there is interference on your current link. You can verify that the alignment is as good as it gets or you can go with an external antenna with a higher gain if the 1300 allows you to have external antennas.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
