Outgoing VPN to Remote Network
Jun 10th, 2008
I have an ASA5510 that I would like to configure to allow outgoing vpn connections to other networks/customers. I am using a PAT address for all other outgoing sessions. I only seem to be able to allow outgoing vpn connections if I statically map public IPs' to internal Private IP's then allow incoming GRE to the public ip.
There must be an easier way that doesn't require static IPs.
Thanks!
smahbub Mon, 06/16/2008 - 06:42
You can limit remote access VPN users to only the areas of the network that you want them to access when you Create access lists and associate them with group policies.Also associate those group policies with tunnel groups.
Refer the following url for more information on remote access vpn:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_configuration_example09186a0080641a52.shtml
branfarm1 Wed, 02/04/2009 - 05:28
Were you ever able to find a solution for this problem? I'm experiencing the same issue.
--Brandon
