3750 show config display problem
rdotson
I have several 3750-48P running version c3750-ipservicesk9-mz.122-44.SE2 IOS and on some of the switches, when you telnet to them, and do a show config, the screen scrolls through the whole config without pausing. On other switches that are exactly the same, as far as I can tell, they pause after a page of information.
Collin Clark
To set the number of lines on the current terminal screen for the current session, use the terminal length EXEC command.
terminal length screen-length
24 is the default
Hope that helps
8 Replies 8
Collin Clark
24 is the default
Hope that helps
bang on target Collin. +5.
-> Sushil
Excellent, do this stay in after a reboot?
Save it and it will (write memory)!
Actually that command only works in the current session.
terminal length
Syntax Description
screen-length
Your desired number of lines on the screen. The router uses this value to determine when to pause during multiple-screen output. A value of zero prevents the router from pausing between screens of output. When the output exceeds the screen length, it scrolls past.
Defaults
24 lines
So if you disconnect and come back in it's back to zero?
Works for me across multiple sessions as long as I save before exiting.
The correct way to fix it is under the VTY settings.
line vty 0 4
length 24 (default)
mine was set to 0.
Ahhh, must override the global setting. Thanks for keeping us updated.
Innovations in Cisco Full Stack Observability - A new webinar from Cisco
