Pager lines - ACE Mod
rdanevich
Anybody know the command to set pager length to 0 (disable buffer) on the ACE module?
Collin Clark
terminal length lines: Sets the number of lines displayed on the current terminal screen. This command is specific to only the console port. Telnet and SSH sessions set the length automatically. Valid entries are from 0 to 511. The default is 24 lines. A selection of 0 instructs the ACE to scroll continuously (no pausing).
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A1/configuration/administration/guide/basiccfg.html
Hope that helps
Thank you. I was thinking along the lines of a firewall and not a router. Terminal length 0 worked and was what I was looking for.
