Broadcast a message
Jun 10th, 2008
Hello
I would like to develop a script that calls multiple phone numbers at the same time.
I made a few tests and the only way I found to do this is to use 2 applications . The main application triggers, several times, the second application which in turn calls one number per instance (I used the "trigger application" step and the synchronous option in the main script).
BTW I have not found no documentation on the "trigger application" step. Anyone used this?
The only problem is that I cannot pass variable parameters between applications.
Does anyone have any ideas how to pass variables to another application at runtime?
Has anyone done a script to call multiple phones simultaneously?
Thanks in advance
Ovidiu
