public key for authenticating
Jun 10th, 2008
is there a way to use public key authentication in addition to user based authentication in IOS similar to the authentication feature available in Linux where you can create a pair, copy the public key to the remote server and use your private key to authenticate?
thank you,
Bill
Overall Rating: 5 (1 ratings)
WILLIAM STEGMAN Mon, 06/16/2008 - 12:54
I see, so instead of putting a public key on the router, put a certificate on the radius server and the client wanting to connect. EAP/TLS
thank you
