6509E Model
Jun 10th, 2008
after the boot up of the Switch SyStem
Led is Orange and not Green, any paticular reason Why.
Thanks for the help
francisco_1 Tue, 06/10/2008 - 14:55
do you have multiple sup 720 line card on the 6509 or just a single?
francisco_1 Tue, 06/10/2008 - 15:04
sounds like your card is not loading up properly. to troubleshoot, connect a console cable to the console port to see why the card is not booting.
francisco_1 Tue, 06/10/2008 - 15:08
also to have your sup 720 engines in active/standby, you need to have the same ios codes on the sup 720 cards.
Mark Yeates Tue, 06/10/2008 - 15:07
The orange system LED means that the module is powering up or a minor hardware fault has occurred. I would recommend looking at your logs, and and run some diagnostics on the supervisor. Please paste the output of the "show
module" command.
Mark
Seroj Hacopian Tue, 06/10/2008 - 15:10
6509E-HOVM_CORE1#show module
Mod Ports Card Type Model Serial No.
1 4 CEF720 4 port 10-Gigabit Ethernet WS-X6704-10GE SAD114300RU
5 2 Supervisor Engine 720 (Active) WS-SUP720-3B SAD113203YL
6 2 Supervisor Engine 720 (Hot) WS-SUP720-3B SAD1141072S
Mod MAC addresses Hw Fw Sw Status
1 001e.4a7d.8e50 to 001e.4a7d.8e53 2.6 12.2(14r)S5 12.2(18)SXF1 Ok
5 0017.944a.8964 to 0017.944a.8967 5.4 8.4(2) 12.2(18)SXF1 Ok
6 0017.944a.9744 to 0017.944a.9747 5.4 8.4(2) 12.2(18)SXF1 Ok
Mod Sub-Module Model Serial Hw Status
1 Centralized Forwarding Card WS-F6700-CFC SAD11420154 4.0 Ok
5 Policy Feature Card 3 WS-F6K-PFC3B SAD113109KF 2.3 Ok
5 MSFC3 Daughterboard WS-SUP720 SAL1129UZ2V 3.0 Ok
6 Policy Feature Card 3 WS-F6K-PFC3B SAD114200YE 2.3 Ok
6 MSFC3 Daughterboard WS-SUP720 SAD114203D6 3.0 Ok
Mod Online Diag Status
1 Pass
5 Pass
6 Pass
all modules look OK
francisco_1 Tue, 06/10/2008 - 15:19
both cards looks fine to me.
you have two sup 720 engines, one is slot 5 as the active and the other in slot 6 as standby. onw which one is the led amber?
Mark Yeates Tue, 06/10/2008 - 15:29
Do you by chance have both power supplies on and plugged in? The light will turn amber if there is only one active power supply.
Seroj Hacopian Tue, 06/10/2008 - 15:37
Thanks I did check the power supply connection to the Ups and one Had come Loose
after reseting the connector Led turned to Green.
Thank you for the support
Mark Yeates Tue, 06/10/2008 - 15:19
Yes everything looks OK thus far. Try the "show diagnostic content module 5" command. This will show the advanced diagnostics on the line card, and show any failed tests.
ranraju Sun, 07/24/2011 - 08:16
"show module" output shows that both the supervisors are up and have passed all the diagnostic tests - so both the supervisors are working fine and in good state. If there is any problem with the module then you would see it in the "show module", "show logging buffer 1023" & "show log".
We can also clearly see that the standby supervisor is in redundant hot state, and has synced up with the active. So i dont see any issues with any of the modules.
Ranganath
(TAC)
