HUM UPMDb won't start
Answered Question
Jun 10th, 2008
Since we ran out of disk space HUM isn't working.
Disk was freed, but things wren't running right so did a net stop crmdmgtd which never completed.
In the end had to do a reboot. Have tried stop/start crmdmgtd but the UPM processes won't start.
Can't seem to find a log that gives any clues. pdshow attached
Is there a lock somewhere that needs to be cleaned?
Correct Answer by Joe Clarke about 8 years 8 months ago
The best you can hope for is that the database transaction log has become corrupt. To check this, shutdown dmgtd, then look at NMSROOT\databases\upm. If you see a upm.log in there, delete it (del /f/q upm.log). Then, run:
NMSROOT\objects\db\win32\dbsrv9 -f NMSROOT\databases\upm\upm.db
Then restart dmgtd, and the UPM database engine and monitor should start. If not, then the upm database is most likely corrupt, and will have to be restored from a known good backup, or reinitialized. To reinit, run:
NMSROOT\bin\perl NMSROOT\bin\dbRestoreOrig.pl dsn=upm dmprefix=UPM
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Tue, 06/10/2008 - 18:41
GRAEME DANIELSON Tue, 06/10/2008 - 19:46
thanks, I'll give it a try. We're running in eval so data loss not too much of a problem
GRAEME DANIELSON Thu, 06/12/2008 - 03:36
Success. After shutting down, removing upm.log then running dbsrv9 -f as suggested, all seems good again. Thanks
