06-10-2008 09:30 PM
Is Cisco MARS able to do vulnerability and security assessment of host (server) and network devices like, for example, Nessus?
Thank you.
Best regards.
Massimiliano.
Solved! Go to Solution.
06-11-2008 03:24 AM
The Cisco MARS has Nessus signatures built-in to it, which it can use to scan end-hosts, please have a look at this link:
http://cio.cisco.com/univercd/cc/td/doc/product/vpn/ciscosec/mars/4_3/uglc/cfgover.htm#wp1248893
"Vulnerability Assessment
Host OS and Patch Level. When a signature fires on an IDS and it is reported to MARS, MARS can either launch a targeted scan using Nessus, or query a vulnerability assessment system that helps determine whether the target was vulnerable. "
http://cio.cisco.com/univercd/cc/td/doc/product/vpn/ciscosec/mars/4_3/uglc/cfgover.htm#wp1173849
Farrukh
06-11-2008 03:24 AM
Farrukh
06-26-2008 08:39 AM
I read the notes regarding the automated scan performed when IDS events are reported, but I'd like to know if the vulnerability scan can be manually triggered for the hosts/networks I'd like to check. There should be some method (at least from the command line)...
06-26-2008 08:56 AM
There seems to be no such command:
Why don't you want to use Nessus (which is free and open source itself) instead? Just wondering?
Farrukh
06-26-2008 09:29 AM
Some customers (who tend to put security ahead of costs) are generally more happy to allow Cisco boxes onto their premises compared to untrusted open-source stuff.
Joe
06-26-2008 01:21 PM
Well the trusted/untrusted debate is quite controversial and 'relative' from person to person, so I prefer not to delve into that :). Specially since Cisco is using the 'same' signatures in MARS.
Anyway thanks for the clarification.
Farrukh
06-26-2008 09:34 AM
Sorry, I forgot : cost is also a factor. I currently need more HW in order to run Nessus scans when I've already got it in the MARS appliance!
Regards, Joe
06-26-2008 01:59 PM
My understanding is that MARS does very limited checks, and it's almost guaranteed to be way out of date. You can't even get updates to Nessus for free anymore.
