voicemail with Pstn
Jun 11th, 2008
hi all,
i've installed unity express with ccme in uc520, i configured voicemail with all steps, the problem is when i try to call voicemail i reveive the Operator message and not the greeting message, i use fxo for my connection with the operator, plz how can fix this pb
best regards
Jaime Valencia Wed, 06/11/2008 - 03:42
does it work internally?
depending on what you send from the pstn you can configure something like thi:
username brian phonenumberE164 "0882295690"
of course change brian for your user and the phone number
if this helps, please rate
m.elmaaroufi Wed, 06/11/2008 - 06:11
i think that i've a problem with my dial-peer, because internally i heard a busy tone, i need to configure a correct dial-peer
