CSM VPN Discovery
Jun 11th, 2008
My problem is that, after i discover a GRE H&Spoke VPN CSM changes the configuration by clearing the tunnels ip address on the hub and adding it to a loopback interface wich is afterwards referenced by the tunnel interface with ip unnumbered.
If there is a static route to the other end of the tunnel then pachets go to the loopback interface because it is connected to the subnet so the connection fails
Is there a workaround? I searched the user guide but it's nothing written on how to modify this behavior.
