Find the SNMP OID for determining Cisco CatOS
Jun 11th, 2008
hi,
i want to automate a tool with SNMP.
i don't know if exist a snmp OID for determining if a switch is CatOS or IOS.
Can you help me?
FCostalunga
Collin Clark Wed, 06/11/2008 - 05:46
  • Purple, 4500 points or more
<font size="2"> 1.3.6.1.2.1.1.1.0</font>
This OID will tell you the model of the device and the IOS/CatOS version.
Help that helps.
Joe Clarke Wed, 06/11/2008 - 09:57
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
In general, if the sysObjectID starts with 1.3.6.1.4.1.9.5 it's a CatOS device. Devices with a sysObjectID starting with 1.3.6.1.4.1.9.1 are IOS devices. Note: this is not a hard and fast rule as there are many non-IOS devices that have a 1.3.6.1.4.1.9.1 sysObjectID. However, if all your devices are either CatOS or IOS, then this should work for you.
