where download IPCC WebView templates
Jun 11th, 2008
Does any body have some special WebView templates for IPCC? For example to see the longest call on the queue?
Thank you very much
adignan Wed, 06/11/2008 - 03:41
Unfortunately, the elusive, "Longest Call Queued" of the day is not in any of standard Webview reports. It would have to be a custom report.
adignan - CDW
*please rate helpful posts
webstd.design Wed, 06/11/2008 - 13:10
Can you share this template or where I can download it? As I know , I can make templates by Infomaker, but for only one template it's not the bets solution
adignan Thu, 06/12/2008 - 04:47
I don't have a template that will give you the "Longest Queued Call" of the day broken down by Call Type.
rbua Thu, 06/12/2008 - 04:54
Not to say that each every IPCC version requires its own Powerbuilder.
Riccardo
gtechfred01 Fri, 06/20/2008 - 09:07
webstd.design,
It is an involved process to get LCIQ added to your reports since Cisco doesn't seem to see the value in the metric
Here's a high level:
1. Develop a query on the Route_Call_Detail table that pulls the LCIQ info
2. Create a New DB and table on your HDS or AW that can house the LCIQ data from your query in step 1.
3. Populate the table with as much historical data as you want to offer
4. Setup SQL Jobs to perform the data population and removal (so your DB doesn't get too big)
5. Add the LCIQ information to whatever Cisco report you want it in via Infomaker.
Hope this helps!
webstd.design Tue, 02/10/2009 - 06:37
I didn't find any interesting templates for my request?
We can consolidate for get IPCC templates
