AppAdmin shown nothing
Jun 11th, 2008
Hi Team,
I have problem with CRS 5.0
After initial setup and configuring the IVR, appadmin shown nothing.
I open http://localhost/CRALogin/AppAdminLogin
and see the Login page. Input login and pass and press Enter. Then see the white page in IE. And nothing happend. The IVR is still working.
I trying method with CLASSPATH entries. Doesnt help.
Sure that answer is simple. Thank you )
Overall Rating: 5 (1 ratings)
adignan Wed, 06/11/2008 - 03:38
  • Blue, 1500 points or more
What are you logging in with? Administrator/ciscocisco?
Also, are you sure your initial setup was accurate?
engineercbs Wed, 06/11/2008 - 05:49
Maybe also that screenshots are help.
I have these error after trying to run "Cisco CRS Admin Utility"
Riccardo Bua Wed, 06/11/2008 - 03:46
  • Cisco Employee,
do you get any error message on HTTP 500 on the status bar? What is your browser? I.E. 6.0? Try setting the appadmin page in the trusted site list are you still getting a similar scenario?
Please attach a screenshot of the outcome.
Riccardo
engineercbs Wed, 06/11/2008 - 04:01
No error. Im attached screenshots.
After i click Log On next page (white screen) is appear immediately. Its too fast, i think that CRS scripts even doesnt execute.
P.S: And yes, it doesnt matter what Login/Password to type. Administrator/ciscocisco doesnt work.
Riccardo Bua Wed, 06/11/2008 - 06:31
  • Cisco Employee,
Try to click on add/remove programs and select the installation saying repair it might fix whatever security issues you are running into.
Riccardo
engineercbs Wed, 06/11/2008 - 06:46
CRS cant be add/removed.
I also tryed Run CRS setup and choose Repair. It doesnt helpd.
Riccardo Bua Wed, 06/11/2008 - 06:54
  • Cisco Employee,
I would recommend removing it with the CD by selecting setup option and then try to reinstall, my take is that something went wrong, if this doesn't do please raise a case to get some remote assistance.
Riccardo
engineercbs Wed, 06/11/2008 - 07:05
Ok the problem was solved by restore the C:\Program files\wfavvid folder from backup.
For that you also need to stop all CRS services in
Start->Programs->Cisco CRS Administrator->Cisco CRS Serviceability Utility.bat
After the restore wfavvid folder. Activate all services and reboot the system.
jmaat Thu, 08/14/2008 - 01:05
I have the same issue with CRS 5.0(2) Build 064. Sometimes I can reach this page, sometimes I can't. Then I get a complete empty white page. It's always possible to access this page from the local machine http://127.0.0.1/appadmin
Jeroen
jmaat Thu, 08/28/2008 - 01:02
This is not the issue. I don't even get the login page.
-Jeroen
mnathlic Sat, 08/16/2008 - 15:31
If you are using IE 7 then check to make sure the "Use TLS 1.0" is checked under security options.
dsobrinho Fri, 12/05/2008 - 07:52
  • Red, 2250 points or more
I have the same problem. During one week the IPCC server works fine, but, after the web appadmin begun present the same problem reported above. The IIS is not restarting in services tools. I am trying to find some information about that and see if have an update packege to solve this.
dsobrinho Fri, 12/05/2008 - 08:07
Symptom:
AppAdmin Page will not load, "Page can not be displayed" message on the
browser.
--World Wide Publishing Service stuck in stopping status if IIS attempted to
be restarted.
Conditions:
1.Open Browser
2. Type the following url http://crsIPAddress/appadmin
3. Receive page can not be displayed or blank page
If you attempt to restart IIS at this time, the only workaround is to reboot
the server.
4. Go to services (start-run-services.msc)
5. Try restarting IIS services, restart will cause world wide publishing
service (co-dependent on IIS service) to be stuck in stopping status
Workaround:
Do not attempt to restart IIS . Instead, do the following steps -
1. Open Internet Explorer and type http://crsIPAddress:6293/appadmin/
2. Login to appadmin and go to Control Center page.
3. Select the CRS Administration process radio button and click
the "Restart" button.
4. Exit the browser and launch appadmin normally from the Start Menu.
Alternatively, if this is an HA setup, login to appadmin from the 2nd node,
go to the Control Center page, select the broken node, and restart it's CRS
Administration process.
