two bgp as
Answered Question
Jun 11th, 2008
Is it possible to have two different BGP AS in the same router?
Thank's
Marcelo
Correct Answer by Harold Ritter about 8 years 11 months ago
Marcelo,
You cannot use this command on an iBGP peer. You can inverse the logic though, change your "router bgp" ASN to 65200 and use the local-as command on the peer to ASN 11664 instead as follow:
router bgp 65200
neighbor 77.1.248.25 remote-as 65200
neighbor 154.0.17.129 remote-as 11664
neighbor 154.0.17.129 local-as 65194 no-prepend replace-as
Overall Rating: 5 (2 ratings)
paolo bevilacqua Wed, 06/11/2008 - 04:42
  • Hall of Fame,
    Founding Member
Yes, in a kind of virtual manner. That is because you can manipulate AS numbers in any way you want.
paolo bevilacqua Wed, 06/11/2008 - 04:49
  • Hall of Fame,
    Founding Member
Are you familiar with BGP configuration and AS path manipulation ? All that is documented in the cisco manuals.
That is the pre-requisite for what you want to do.
MARCELO MATURO Wed, 06/11/2008 - 05:42
I applied this configuration but I can't get the peering. There is the following error:
Jun 11 10:38:04: %BGP-3-NOTIFICATION: sent to neighbor 77.1.248.25 3/11 (invalid or corrupt AS path) 3 bytes 400200
Harold Ritter Wed, 06/11/2008 - 05:52
  • Cisco Employee,
Marcelo,
Can you send a bit more info about the topology and configuration that you are trying to implement.
MARCELO MATURO Wed, 06/11/2008 - 06:06
This is the configuration. I need peering with 2 differente AS. The AS 65200 see me as 65200 y de 11664 see me as 65194.
router bgp 65194
no synchronization
bgp log-neighbor-changes
redistribute connected
neighbor 77.1.248.25 local-as 65200 no-prepend replace-as
neighbor 154.0.17.129 send-community
no auto-summary
Correct Answer
Harold Ritter Wed, 06/11/2008 - 06:53
  • Cisco Employee,
Marcelo,
router bgp 65200
Harold Ritter Wed, 06/11/2008 - 04:48
  • Cisco Employee,
Marcelo,
You can only assign one AS number to your BGP router process but you can change that AS number when you connect to BGP peers by using the local-as feature.
