Ip address assignment via DHCP for an anyconnect client
jeyriku
On my Asa(with asdm)i configured the DHCP server in the managment tab to allow dynamic Ip assignment for my lan devices (on the inside interface). I tried to allow Ip assignement via my Lan DHCP server for my VPN SSL client located on a remote site but it didn't work (they mount the tunnel on the outside interface of the Asa). I would have liked to know if someone could advise me to do so. When i checked the DHCP box in the different connection profiles my client still didn't receive any address. Are there anything i need to allow to perform this action. I hope someone can help.
PS: Here is the message i get when i start the Cisco anyconnect client:
"An error was received from the secure gateway in response to the vpn negociation request. Please contact your network administrator. The following message was received from the remote VPN device: No assigned Address"
Best regards.
23 Replies 23
owillins
Level 6
Level 6
The error message indicates that the ASA returned an HTTP error to the client when the client attempted to establish an SSL connection.
I understand this To. But deeper, it means that my Lan DHCP server can't deliver IP address to my VPN SSL client. I don't understand why!! As long as you check the "DHCP" box it should work, but at the moment it doesn't. Can you help me?
Best Regards,
Can you post output of webvpn debugs?
Farrukh
Here is a copy of syslog entries which best describe what is happening:
"Device completed SSL handshake with client outside: X.X.X.X:XXXX"
"TunnelGroup GroupPolicy User IP No address available for SVC connection"
The SSL connection starts without problems, but as soon as i need to be assigned an ip address, it doesn't work. The odd thing is that in both profile the DHCP box is checked.
Can someone help?
Best regards
Can you post the webvpn related CLI configuration?
Farrukh
Hi, here is what you asked me for:
webvpn
enable inside
enable outside
csd image disk0:/securedesktop-asa-3.2.1.103-k9.pkg
svc image disk0:/anyconnect-win-2.2.0128-k9.pkg 3
svc enable
cache
max-object-size 5000
group-policy DfltGrpPolicy attributes
dns-server value X.X.X.X
dhcp-network-scope X.X.X.X
vpn-tunnel-protocol IPSec l2tp-ipsec svc webvpn
default-domain value XXXXXX
intercept-dhcp 255.255.255.XXX enable
nac-settings value DfltGrpPolicy-nac-framework-create
webvpn
url-list value Lan_Applications
svc keepalive none
svc dpd-interval client none
svc dpd-interval gateway none
svc ask enable default webvpn
customization value DfltCustomization
tunnel-group DefaultRAGroup general-attributes
authentication-server-group (outside) LOCAL
authorization-server-group LOCAL
authorization-server-group (outside) LOCAL
dhcp-server XXX.XXX.XXX.XXX
tunnel-group DefaultWEBVPNGroup general-attributes
authorization-required
Best Regards,
Jeyriku
Do you have the following in your configuration:
"vpn-addr-assign dhcp"
Note: DHCP assignment is disabled by default
Farrukh
Many thanks for your response
No it doesn't appear but it should as i already typed it before
But the following appear:
"no vpn-addr-assign aaa
no vpn-addr-assign local"
Do you have an idea why it doesn't appear?
Best regards,
No that is ok, it means AAA and LOCAL are now disabled, and DHCP is enabled.
Can you post more aggressive debugs?
Regads
Farrukh
Can you tell me what i need to do? What do you mean by "more agressive"?
kind Regards,
I meant more detailed/verbose debugs, please attach the output of the following:
debug dhcpd event
debug dhcprelay event
debug webvpn tunnel
debug webvpn svc
debug webvpn html
Farrukh
Ok,
I do that for you and will keep you updated.
Many thanks for your help.
Here is an attachment with the debug messages
Kind Regards,
The issue seems to be your DHCP server, check the DHCP server IP /scope once again. Also any logs on the DHCP server end.
7|Jun 19 2008 10:00:10|711001: Validating address: 0.0.0.0
7|Jun 19 2008 10:00:10|711001: CSTP state = WAIT_FOR_ADDRESS
7|Jun 19 2008 10:00:10|711001: webvpn_cstp_accept_address: 0.0.0.0/0.0.0.0
7|Jun 19 2008 10:00:10|711001: webvpn_cstp_accept_address: no address?!?
7|Jun 19 2008 10:00:10|711001: CSTP state = HAVE_AD
Farrukh
