Caller ID
Jun 11th, 2008
Hi All,
This may seem like a stupid question. We have CallManager 4.2 setup. When I call from my desk Cisco Phone to my office cell phone, the correct Caller ID info shows up. But, when I call from my desk phone or again to one of our employees cell phone, my info on the employees phone comes up as "private". I may have an idea as to why this is. But, I was wondering that I get some opinion from some more qualified professionals here. Thanks in advance.
Overall Rating: 4 (1 ratings)
Rob Huffman Wed, 06/11/2008 - 06:13
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Naveen,
There is no such thing as a stupid question, they are all valid here :) Does this behaviour happen on every call to your co-workers mobile? What type of trunking are you using POTS/FXO or PRI (E1/T1)? Is your co-workers Cell from the same provider? Do other calls to his phone show the proper CLID?
Let us know,
Rob
Naveen Raj Janardhan Wed, 06/11/2008 - 06:35
There are about 10 people in my department 3 of them showed up as either "Unknown" or "Private", remaining of them showed correct caller id.
We are using PRI as our trunking. All our cell phones are provided by the same provider. Mostly, all desk phone calls on the employees cell phone shows up as "private".
Rob Huffman Wed, 06/11/2008 - 09:21
  • Hall of Fame,
    Founding Member
Hi Naveen,
Any problems with CLID when calling Land Lines?
Rob
Naveen Raj Janardhan Wed, 06/11/2008 - 11:11
No problem with caller id when calling to a land line. The caller id can be seen at the other end.
Jaime Valencia Wed, 06/11/2008 - 11:54
  • Cisco Employee,
  • Hall of Fame,
    2011
are all the calls being handled by the same PRI? or do you have one for landlines and one for mobiles?
a debug isdn q931 would show you the setup message and within it you can see the calling and called parties, if you're sending the right digits then it might be that someone in the middle is changing the info and a call to the telco might be a good idea
javalenc
if this helps, please rate
Naveen Raj Janardhan Wed, 06/11/2008 - 12:22
The calls are actually being handled by the sam PRI. But, can't it be the provider who could have turned off the Caller ID feature on the cell phone?
I will check what shows up on the command. thanks.
Naveen Raj Janardhan Thu, 06/12/2008 - 09:37
Jamie, can you please suggest on how to use the debug isdn q931 command? when I put in the command on the gateway it came up as " debug isdn q931 ON" not sure how to proceed from here. thanks.
Jaime Valencia Thu, 06/12/2008 - 09:50
  • Cisco Employee,
  • Hall of Fame,
    2011
#term mon
#debug isdn q931
test call
#u all
#no term mon
javalenc
