WAN latency
Jun 11th, 2008
I have a WAN link with high latency, usually around 950ms on my 'ping' replies. I'm using EIGRP but my neighbor adjacency drops of occasionally. Would using static routes solve this problem? My only concern is that I have two links connecting to the site, without a dynamic route will I be able to keep redundancy?
Overall Rating: 5 (1 ratings)
Jon Marshall Wed, 06/11/2008 - 07:24
Jonathan
Rather than revert to static routes you may want to consider increasing the hello times on the routers for EIGRP.
http://www.cisco.com/en/US/tech/tk365/technologies_white_paper09186a0080094cb7.shtml#neighbordiscovery
You could use static routes if you wanted to. Are both links being used all the time or is one active and one passive - you can use a floating static for the passive link.
Jon
jamrjor Wed, 06/11/2008 - 17:00
Thanks, I didn't think about using a floating static. Both links will not be used at the same time.
Joseph W. Doherty Wed, 06/11/2008 - 17:39
950ms latency!? What are the properties and utilization of these links? What type of queue management (e.g. FIFO, WFQ, etc.)?
Reason I ask, I wonder if EIGRP packets are being overly delayed.
jonathancert Thu, 06/12/2008 - 20:18
I'm using FIFO. What type of queue do you recommend? Yes, the latency is high, nothing i can do about that. We are talking modem, ATM's and satellite links. Shooting data across the world.
Joseph W. Doherty Fri, 06/13/2008 - 02:56
Ah, satellite; certainly explains high latency.
If supported, and if the platform can provide it without overtaxing itself, I prefer FQ or WFQ to FIFO to minimize one (or a couple) of bandwidth heavy flows from overly delaying or causing synchronous tails drops with other traffic. It might also help with EIGRP.
mpatus Fri, 06/27/2008 - 08:14
You may also try using LLQ and put your EIGRP traffic in the PQ. That should keep your EIGRP adjacencies up.
jonathancert Mon, 06/30/2008 - 17:13
I'm not familiar with alot of queuing methods. Is this a difficult setup and does it need to be implemented on the local and remote router.
Joseph W. Doherty Mon, 06/30/2008 - 17:49
Difficulty depends on how complex the queuing configuration. If you don't have a form of FQ, try it first.
If the interface is a serial of 2 Mbps or less, try:
interface serial #
fair-queue
If the interface is faster than 2 Mbps, try CBWFQ:
policy-map CBWFQ
interface FastEthernet #
service-policy output CBWFQ
If the interface is faster than the capacity of the link, "shape" to the capacity, e.g.
traffic-shape rate ### (in bps)
Placement is on both ends outbound.
jonathancert Tue, 07/01/2008 - 19:04
Wow, everyone is giving me some great ideas. I plan on trying WRED combined with traffic-shaping this weekend and monitoring the status for any improvement or degrade.
Mark Yeates Mon, 06/30/2008 - 18:06
As a former tech controller there isn't much you can do to reduce the latency over a satellite link. Queuing methods will only help if the link is saturated, and will provide little help overall in your current situation.
Mark
jonathancert Mon, 06/30/2008 - 18:13
Go Waterwalker! I have given up on the latency issue, can't do anything about the transmission medias in use. The link is also saturated, I using Netflow to monitor it and sometimes I get burst at 110%. Working on getting the bandwidth increased but until that red tape gets conquered, maybe queuing will keep things stable.
Mark Yeates Tue, 07/01/2008 - 04:08
I would definitely recommend a good queuing strategy to help with congestion. Just remember that it won't replace an upgrade in bandwidth, but like you said keep things more stable and it should help. Good Luck!
Mark
