vpn tunnels on different interfaces
Jun 11th, 2008
do i just configure a new cryptomap and add it to the second interface?
will it interfere with the vpn cryptomap configured on the outside interface?
do i need to create a new nonat acl?
do i then have something like:
nat (inside) 0 access-list InsideNat0
nat (int2) 0 access-list RmtNat0
crypto map outside_map interface outside
crypto map int2_map interface int2
isakmp enable outside
isakmp enable int2
Farrukh Haroon Thu, 06/12/2008 - 05:24
Yes you can just make two different crypto maps and apply them to the respective interfaces. If both interfaces are 'sourced' from the same interface, then one NAT 0 ACL (with entries/lines covering each VPN's traffic) is enough. It depends on the 'interesting traffic'.
