Displaying Object Groups on ASA
Answered Question
Jun 11th, 2008
This has been bugging me for a while. How do you show object groups from the command line. WHen I do a show ? I do not see network-object or group objects as an option.
This is in my config:
object-group service pop3Services tcp
port-object eq pop3
port-object eq 995
edgefw-pri# sh object-group service pop3Services tcp
ERROR: % Invalid input detected at '^' marker.
edgefw-pri#
Currently I have to do:
edgefw-pri# sh run | begin object-group service pop3Services tcp
port-object eq pop3
port-object eq 995
which is a pain. There has to be a better way.
Correct Answer by Jon Marshall about 8 years 8 months ago
Try either
1) sh object-group id pop3Services
or
2) sh running-config object-group id pop3Services
Jon
Overall Rating: 5 (1 ratings)
Correct Answer
Jon Marshall Wed, 06/11/2008 - 07:47
Try either
or
Jon
vman1976nj Wed, 06/11/2008 - 07:51
The second one worked like a charm:
edgefw-pri# sh object-group id pop3Services
edgefw-pri# sh running-config object-group id pop3Services
port-object eq pop3
port-object eq 995
edgefw-pri#
Thanks, thats exactly what I needed.
