Softkey/Line question
Answered Question
Hello Everyone,
On my 7940 phone when I have a call on line 1 and a second call comes into my phone on line 2 I keep my soft key options "hold, transfer, etc" or my connected soft key template. However, I have a user who has a 7960 phone, when the user is on Line 1 and a second call comes into line 2 their connected soft key template goes away and she receives the ring in soft key template. My question is where do I change this feature so that the end users phone performs like mine, maintaining their original soft key template when a call comes in on the second line.
CM4.1.3sr5d
Correct Answer by Rob Huffman about 8 years 9 months ago
Hi Daniel,
It sounds like this setting is different :)
Try changing the System setting Auto-Line Select. With this Enabled the Display Focus (and Softkeys) always switch to the new incoming call. So if disabled the focus will stay on Call #1.
Also available on an individual phone via this setting;
Device>Phone>Phone Configuration>Product Specific Configuration>Auto Line Select>Disabled
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
thisisshanky Wed, 06/11/2008 - 08:07
  • Purple, 4500 points or more
Does that user with 7960 have a custom softkey template ?
Correct Answer
Rob Huffman Wed, 06/11/2008 - 08:33
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Daniel,
Hope this helps!
Rob
Rob Huffman Wed, 06/11/2008 - 09:29
  • Hall of Fame,
    Founding Member
Hi Danny,
That is crazy talk ;-) Glad to be of some small help though.
Take care,
Rob
