VACL - for monitoring VLAN traffic Question
Jun 11th, 2008
if i have a vlan that spans multiple switches would i have to create a VACL on each switch that has ports in that VLAN?
I guess the same question applies to normal span ports would i have to creat a span port on each switch to capture all data from that vlan?
dgroscost Wed, 06/11/2008 - 15:59
Create & apply the VLAN filter (ACL) on your L3 device doing the InterVLAN routing.
ogormam2 Thu, 06/12/2008 - 04:50
Hi thanks for your response but what if i also need to capture traffic within the VLAN?
