FSIP Controller -----WIC-1DSU-T1-V2 on 3845
Answered Question
Jun 11th, 2008
Hi All,
We are trying to replace a 7000 router with 3845 router in one of our customer location. In relation to this, on the 7000 router, currently we have 2 serial interfaces on FSIP controller,where one serial interface connect to a CSU/DSU and another one connect to a serial interface on 2500 router. We are trying to understand, what card would be required in 3845 router to move these circuits.
We were thinking to use WIC-1DSU-T1-V2 on 3845 router to replace one serial circuit which is connected to an external CSU/DSU,in that way, we can eliminate the CSU/DSU and for the other serial interface, we are thinking to use an HWIC -WIC-1T. Is these hardware changes would work or even this is the right/optimised way to do it ?
Any help would be appreciated .
Anantha Subramanian Natarajan
Correct Answer by Collin Clark about 9 years 1 month ago
Yup, the WIC-1DSU-T1-V2 has a built-in CSU/DSU (RJ-48 connection) and the HWIC-WIC-1T is a serial connection (DB60 no CSU/DSU).
Hope that helps.
Overall Rating: 4 (3 ratings)
Correct Answer
Collin Clark Wed, 06/11/2008 - 08:29
  • Purple, 4500 points or more
Hope that helps.
anasubra_2 Wed, 06/11/2008 - 08:31
Hi Collin,
Thank you very much
anasubra_2 Wed, 06/11/2008 - 09:13
Hi Collin,
I have an question,assuming we want to retain the CSU/DSU externally and want to terminate on 3845. In this scenarion,do we have a equivalent WAN interface card in 3845 for FSIP controller in 7000. The idea to find this is,so that we are thinking that, we don't need to worry about the interface type on new 3845 and the cable required for those.
Kindly let us know.
anasubra_2 Wed, 06/11/2008 - 09:22
Hi Harold,
Thanks for the link......
Is there a way to find the cable type from the router show commands ?
anasubra_2 Wed, 06/11/2008 - 10:47
Hi Collin,
I couldn't find the cable type by viewing the show interface command . Any other method,by which we would be able to confirm the same ?
Collin Clark Wed, 06/11/2008 - 10:53
It's not in plain English. Can you post the results of the show interface?
anasubra_2 Wed, 06/11/2008 - 12:58
Hi Collin,
Sure ..Please find the show interface output for the interfaces on discussion.
Serial1/4 is up, line protocol is up
Hardware is cxBus Serial
Description: xxxxxxxxxx
Internet address is xxxxxx
MTU 1500 bytes, BW 1544 Kbit, DLY 20000 usec,
reliability 255/255, txload 30/255, rxload 3/255
Encapsulation HDLC, crc 16, loopback not set
Keepalive set (10 sec)
Restart-Delay is 0 secs
Last input 00:00:07, output 00:00:00, output hang never
Last clearing of "show interface" counters 1y34w
Input queue: 0/75/0/185718 (size/max/drops/flushes); Total output drops: 526909
Queueing strategy: weighted fair
Output queue: 0/1000/64/526909 (size/max total/threshold/drops)
Conversations 0/172/256 (active/max active/max total)
Reserved Conversations 0/0 (allocated/max allocated)
5 minute input rate 22000 bits/sec, 14 packets/sec
5 minute output rate 182000 bits/sec, 23 packets/sec
880931560 packets input, 4063336745 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
1334 input errors, 725 CRC, 0 frame, 0 overrun, 3 ignored, 609 abort
908978238 packets output, 219876897 bytes, 0 underruns
0 output errors, 0 collisions, 6 interface resets
0 output buffer failures, 181858926 output buffers swapped out
0 carrier transitions
RTS up, CTS up, DTR up, DCD up, DSR up
bmt7k1#sh interfaces serial 3/7
Serial3/7 is up, line protocol is up
Description: xxxxx
reliability 255/255, txload 13/255, rxload 13/255
Last input 00:00:05, output 00:00:00, output hang never
Input queue: 0/75/0/2 (size/max/drops/flushes); Total output drops: 22375
Output queue: 0/1000/64/22375 (size/max total/threshold/drops)
Conversations 0/198/256 (active/max active/max total)
5 minute input rate 84000 bits/sec, 84 packets/sec
5 minute output rate 81000 bits/sec, 83 packets/sec
3034599067 packets input, 15030845 bytes, 0 no buffer
2911 input errors, 1732 CRC, 0 frame, 0 overrun, 1 ignored, 1179 abort
3042634015 packets output, 2151246439 bytes, 3 underruns
0 output buffer failures, 196818010 output buffers swapped out
36 carrier transitions
Thank you
Collin Clark Wed, 06/11/2008 - 13:05
OK, can you now try show controllers cxbus?
anasubra_2 Wed, 06/11/2008 - 13:52
oh cool..in the controller o/p it mentions as V.35 DTE ---do I have to assume as DB60 cable connected to it ...
Anantha Subramanain Natarajan
Collin Clark Thu, 06/12/2008 - 07:24
I would think yes, but I was also get a pair of eyes on it before I bought anything :-)
anasubra_2 Thu, 06/12/2008 - 07:54
Hi Collin,
