Reject call at H.323 GW
Jun 11th, 2008
I am trying to reject a call at our H.323 GW. I thought I had this correct but the call is still coming through.
voice translation-rule 1
rule 1 reject /8041234567/
voice translation-rule 2099
rule 1 /^2990/ /2099/
rule 2 /^2033/ /2040/
voice translation-profile LD_Trans_1
translate calling 1
translate called 2099
voice-port 0/2/0:23
translation-profile incoming LD_Trans_1
I am trying to reject Translation-Rule 1. I did a Debug Translation Detail and it does not show the call being rejected.
What am I doing wrong?
Thanks in advance
Trae
Rajesh Revuru Wed, 06/11/2008 - 09:11
  • Silver, 250 points or more
What does it show when you test the translation rule by using
test voice translation-rule
Rajesh Revuru Wed, 06/11/2008 - 09:20
Can you post your dial-peer for incoming calls? I guess you have to apply translation-rule in there as well.
PS: If you are in production i would suggest you try after-hours.
cairns-a Wed, 06/11/2008 - 09:26
Thanks for your help. Here is the dial peer. Translation rule 2099 does work as is, so I would think just adding a new translation rule to the translation profile should work.
dial-peer voice 2099 voip
preference 1
destination-pattern 2099
progress_ind setup enable 3
voice-class codec 1
voice-class h323 1
session target ipv4:X.X.X.X
dtmf-relay h245-alphanumeric
no vad
paolo bevilacqua Wed, 06/11/2008 - 15:38
  • Hall of Fame,
    Founding Member
Hi, can you check with "debug isdn q931" that the calling number is indeed what you're trying to reject ?
