Time-Stamp problem
Jun 11th, 2008
Hi Folks,
I've got CUE v 2.3 users reporting that there is a three hour difference between the time-stamp on their missed call log and the time-stamp on the actual voice mail. Where do I begin?
Overall Rating: 5 (1 ratings)
Tommer Catlin Wed, 06/11/2008 - 11:31
  • Green, 3000 points or more
Log into the CUE and check the system on the server. Also check to see if your subscribers are in any time zones that may be reflected in the time stamp
Rob Huffman Thu, 06/12/2008 - 04:28
  • Super Red, 40000 points or more
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Stephen,
Just to add a note to the good tips from Tommer;
Have you tried these commands?
Problem: CUE Clock Not Synchronizing with CME Router Configured as a NTP Server
NTP on the CUE is unable to synchronize with the CallManager Express. The CallManager Express router is configured as a NTP server. The CUE clock is not displaying accurate time. However, CallManager Express displays the correct time.
Issue these commands in order to overcome this problem:
On the CallManager Express router:
ntp master
On the CUE:
ntp server x.x.x.x
!--- Where x.x.x.x is the ip address of the CME router which is configured as a NTP server.
Once the mentioned configuration changes are made on the CUE and CallManager Express, issue the show ntp status command on the CallManager Express router. You should see that the clock is synchronized.
http://www.cisco.com/en/US/products/sw/voicesw/ps5520/products_configuration_example09186a008037f2a9.shtml#k1
Hope this helps!
Rob
tourless27 Thu, 06/12/2008 - 04:54
Wow guys, thanks! I appreciate being pointed in the right direction.
