Syslog configuration on a 6009 (Running IOS)
I am running the latest 12.1 IOS on my 6009 and I was wondering if I can configure syslog to tell me when someone logs in or out of the switch? Would I need to change anything with the logging facility (don't think I need to)?
Right now I have the following set for logging...
Syslog logging: enabled (0 messages dropped, 2 messages rate-limited, 0 flushes
0 overruns)
Console logging: disabled
Monitor logging: level emergencies, 0 messages logged
Buffer logging: disabled
Exception Logging: size (4096 bytes)
Trap logging: level debugging, 6601 message lines logged
Logging to x.x.x.x, 6601 message lines logged
Mark Yeates Wed, 06/11/2008 - 14:21
Typically you would want to use TACACS to log access to your devices. There is a command to log successful, and unsuccessful connection attempts to your switch. Unfortunately your IOS is not current enough to support the commands. You also might try setting your logging buffer to informational, and it should log when users log into the switch. I do recommend using TACACS.
login on-failure log
login on-success log
Hope this helps
Mark
I have tried this on my 3750 and the command is there. I am not seeing anything in syslog though. Here are my settings:
login block-for 30 attempts 30 within 100
login delay 5
no logging buffered
no logging console
no logging monitor
logging 1.2.3.4
I have messages going to syslog, but login messages are not appearing.
Mark Yeates Fri, 06/13/2008 - 12:08
You shouldn't have to use AAA, as long as you are using a local account with a username and password.
glen.grant Sat, 06/14/2008 - 01:58
Right now you have buffer logging disabled so you won't be able to look at anything locally on the box the way it is . As the other person said what you are requested is normally handled thru an authentication server whether tacacs or radius. You need to turn buffer logging on the box and don't use the defaults they are much too small , I would make it at least 3-4 times the default of 4096 at the very least.
