configuring the TwinGig (CVR-X2-SFP) in WS-X45-SUP6-E Sup module
Jun 11th, 2008
I am trying to configure one of the twingig interfaces on a WS-X45-SUP6-E sup module and can not get the interface to come up.
There is a GLC-SX-MM 1 gig GBIC inserted into the Twingig module. the switch seems to recognize that the GBIC is installed because I get a console message when I remove the GBIC.
But when I do a Show Interface Status it indicates there is no GBIC and the interface is inactive. A show interface command indicates the Interface is DOWN\DOWN.
Is there some type of configuration command I need to senter to get this interface to recongnize the existance of the GBIC?
FYI: I have tried multiple GBIC's and both of the 2 TwinGig slots in the Sup modules.
show Interface:
GigabitEthernet1/3 is down, line protocol is down (inactive)
Hardware is Gigabit Ethernet Port, address is 0021.555b.8dc2 (bia 0021.555b.8dc2)
Description: Uplink US-RTN-23L8-6509-1
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
Keepalive set (10 sec)
Full-duplex, Auto-speed, link type is auto, media type is No Gbic
input flow-control is off, output flow-control is off
Last input never, output never, output hang never
Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts (0 multicasts)
0 packets output, 0 bytes, 0 underruns
0 lost carrier, 0 no carrier
Overall Rating: 0 (1 ratings)
mike.rootvik Thu, 06/12/2008 - 08:52
This issue has been resolved. The solution was to use the hw-module command to set the TwinGig module to 1 gig mode.
hw-module module 1 port-group 1 select gigabitethernet
