Routing calls on calling ID
Jun 11th, 2008
Environment:
CCM 6.1/Unity 5.0
T1 PRI with 2851 router
Requirement:
Customer has an 1-888 number. All calls to this number are sent to a T1 PRI in Head office, but their regional offices are across the country. Customer would a solution to route the incoming calls to different city's offices based on caller id(area code), for example, all the calls with Vancouver or Calgary area codes will be routed to Edmonton office. The calls with Montreal or Toronton area codes will be routed to Tonronto office Is it possible to do this without IPCC?
Any suggestions are appreciated.
Kenneth Mohammed Wed, 06/11/2008 - 13:20
  • Silver, 250 points or more
I dont believe that call manager has the ability to route calls based on the calling party number. Perhaps someone else can chime in and give you a more definitive answer, but I believe the answer is no, and that you would probably need an IPCC to accomplish this.
Hope that helped.
paolo bevilacqua Wed, 06/11/2008 - 13:41
  • Hall of Fame,
    Founding Member
Are you using MGCP or H.323 ? The basic technique for the latter is as follows:
http://www.cisco.com/en/US/tech/tk652/tk90/technologies_configuration_example09186a00801c0a88.shtml
but you would apply the DP at reverse, that is having answer-address on the incoming pots DP, mapping to outgoing voip DP.
There is a variation to this technique, that is using COR. That is done not manipulating the numbers but using COR to route on calling number.
Both achieve the same result and is matter of preference which to use.
If you are using MGCP I would not know what to suggest.
michaelzhq Wed, 06/18/2008 - 14:35
I just figure out a solution by using Routing Table in Unity.
