multiples zone local on gatekeeper cluster
Jun 11th, 2008
Anybody know how it works?. I have 2 gatekeeper each one with one local zone and redundandy work fine, but if add another local zone on gatekeeper 1, the endpont is not propagated to cluster so the gatekeeper 2 can't see the endpoint on local zone 3. it is possible?
gatekeeper 1
zone local local1 test.com 192.168.0.1
zone local local3 test.com
zone cluster local test local1
element local2 192.168.0.2 1719
gatekeeper 2
zone local local2 test.com 192.168.0.2
zone cluster local test local2
element local1 192.168.0.1 1719
gpulos Thu, 06/12/2008 - 04:57
  • Blue, 1500 points or more
The gatekeeper 2 will not automatically update to know that 'local3' zone has been added to gatekeeper 1.
You could use a directory gatekeeper to allow for easier administration. When you have a directory gatekeeper and you add a zone to gatekeeper 1, you only need to add that zone to the directory gatekeeper as well.
Then when other gatekeepers need to contact an endpoint in 'local3' zone, that request is forwarded to the directory gatekeeper with a matching zone prefix.
