CTIOS C++ CIL Vs Visual Studio 2005
Answered Question
Jun 12th, 2008
We are using the CTIOS C++ CIL libraries to write an application with the Visual Studio 2005 environment. We are however, unable to build, since the compiler throws linker errors related to the lib files. We have tried using the Visual Studio 2003 environment for the same project and are able to build the code successfully. The CTIOS programmers guide does not have any information about the C++ CIL libraries support in VS 2005. It only says that All C++ applications using C++ CIL 7.1(1) must be built using Visual Studio .NET. Applications using C++ CIL 7.1(1) built with Visual C++ 6.0 are not supported. Kindly throw light on this issue.
Correct Answer by winijenh about 9 years 2 weeks ago
CTI OS 7.5 (along with ICM/CCE 7.5) is planned to be available in Q3CY08. It will support VB2005 for C++ and .NET.
Willem Evert Nijenhuis
CCBU Product Management
Correct Answer by Riccardo Bua about 9 years 2 weeks ago
The C++ CIL 7.0 (C++ class libraries) have not been tested with the new compiler in VS .NET 2005, so if you use C++ CIL with it neither TAC or DE will support them.
This might change with CTIOS 7.5, will get the documentation updated to reflect it.
Riccardo
Overall Rating: 5 (2 ratings)
Correct Answer
Riccardo Bua Thu, 06/12/2008 - 04:10
  • Cisco Employee,
Riccardo
bhaskar27in Thu, 06/12/2008 - 04:15
Riccardo,
Because the document does not contain anything specific to the C++ CIL with VS 2005 it may cost some one a great deal. Request you to expedite the reflection of this in the CTIOS Programmers guide.
Thanks for the clarification,
-Bhaskar.
bhaskar27in Thu, 06/12/2008 - 04:18
Riccardo,
However I would like to know, what is the tentative release date for the 7.5?
Thank You,
-Bhaskar
Riccardo Bua Thu, 06/12/2008 - 04:19
  • Cisco Employee,
No specific release yet date that I could share on the Forum, please contact your sales rep for a direct answer.
Riccardo
Correct Answer
winijenh Thu, 06/12/2008 - 05:36
  • Cisco Employee,
bhaskar27in Thu, 06/12/2008 - 05:49
Hi Willem,
Nice to hear from you.
I am not sure if I understood you. VB2005?
-Bhaskar.
