Port Security question
Jun 12th, 2008
Question is - can Mac-Addresses be present on multiple switch ports at the same time?
For example, a pod of 4 desks with 4 laptop users in. I want port security on the 4 switch ports that the 4 laptops will use but I want the users to be able to be able to plug their laptops in at any of these 4 desks without a violation so would need all 4 mac-addresses of the laptops listed on all 4 switch ports at the same time.
If I try and configure the switch ports using the range interface config command and type the mac-addresses in, then I get a duplicate address notification message and the first port in the range gets all 4 mac-addresses in it's allowed list and the other 3 ports don't get any of them.
Is this possible?
edit - bah sorry - posted in the wrong forum...
celticfc2007 Thu, 06/12/2008 - 04:59
I haven't tested it, but the following should work:
Switch#configure terminal
Switch(config)#interface fa0/1
Switch(config-if)#switchport port-security
Switch(config-if)#switchport port-security maximum 4
Switch(config-if)#switchport port-security mac-address 1111.1111.1111
Just repeat the last command for each MAC address, and repeat the entire process for each port. I don't know if you could use the sticky paramter with maximum 4, less typing
(Disclaimer, the syntax is off the top of my head, no warranty expressed or implied =)
Paul_Edwards Thu, 06/12/2008 - 05:28
Hi thanks for your reply, I originally tried as an example
Switch#conf t
switch#(config)#interface range fa0/1 - 4
switch#(config-if-range)#switchport mode access
switch#(config-if-range)#switchport port-security
switch#(config-if-range)#switchport port-security max 4
switch#(config-if-range)#switchport port-security mac-address 1111.1111.1111
but when I hit return I get the msg :
found duplicate mac-address 1111.1111.1111
The only port which has updated with the mac-address is the first one whereas I was hoping to get it on all 4 ports
switch#(config-if)#switchport port-security mac-addre
Paul_Edwards Thu, 06/12/2008 - 05:30
Switch#conf t
I then tried to add the first mac-address by doing
The only port which has updated with the mac-address is the first one whereas I was hoping to get it on all 4 ports.
Just wondering if it is possible to get a mac-address on multiple ports or not :)
celticfc2007 Thu, 06/12/2008 - 07:55
I was testing it out, I don't think it can be done. I'm thinking the logic, is similar to trying to assign the same static IPs to multiple interfaces.
Good luck.
srue Thu, 06/12/2008 - 11:40
i think you can only use the same mac-address if they are in different vlans.
Paul_Edwards Thu, 06/12/2008 - 22:51
Thanks for the replies - I've found I can do it if I use a different switch for each port, but the amount of switches in the stack is obviously a limiting factor.
Would rate the replies as helpful, but I don't seem to have the option to rate them (nor as you can see do I have the option to edit one of my existing posts without them being added as new replies lol).
