Upgrading IOS on a catalyst 6509 running integrated IOS
Answered Question
Jun 12th, 2008
I need to upgrade the IOS on a catalyst 6509 running integrated IOS.
The current image is stored in sup-bootflash. I like to have this image available if the reload with the new IOS should fail.
QUESTION: Will the 6509 boot on the new IOS if it is placed in bootflash and I code
boot system flash bootflash:new-IOS
boot system flash sup-bootflash:old-IOS
Thanks Simon
gwone4#sh file sys
File Systems:
Size(b) Free(b) Type Flags Prefixes
65536000 25572008 flash rw sup-bootflash:
65536000 65536000 flash rw bootflash:
Correct Answer by Jon Marshall about 9 years 1 month ago
Yes, as Greg says, as long as you have the space you should be fine.
Jon
Correct Answer by gpulos about 9 years 1 month ago
In short, Yes.
It is always a good idea to keep your previous IOS available, in flash if possible, but tftp or other means if no flash avaialable.
As long as you have enough free space for the image, as it looks like you do, you can load the IOS to the flash/bootflash and create your boot system commands to point to the new IOS, in the order you require.
Overall Rating: 5 (2 ratings)
simonvyrdal Sat, 06/07/2008 - 08:10
Jon. Right copy and paste :)
So booting the new image from bootflash should be OK ??
Correct Answer
Jon Marshall Thu, 06/12/2008 - 03:16
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
Jon Marshall Thu, 06/12/2008 - 02:47
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Simon
Yes with the boot system flash... configuration you can specifiy which order you want the IOS versions tried so you should be fine.
Just make sure that you are accurate in your typing or cut and paste, can't count the number of times i've had to retype it in :-)
Jon
Correct Answer
gpulos Thu, 06/12/2008 - 02:54
  • Blue, 1500 points or more
In short, Yes.
