ACS shell command authorization help
Answered Question
Jun 12th, 2008
I wanted to only allow users to use interface command. But when I permit config terminal in ACS shell command set, all the commands are allowed. How can I limited the users to only have the permission for interfacce command?
Correct Answer by Farrukh Haroon about 8 years 4 months ago
Two things could be wrong
1) You don't have the following command on your AAA Client:
aaa authorization config-commands
2) You have clicked the 'Unmatched Commands' = Permit radio option in ACS, have a look at:
Overall Rating: 5 (1 ratings)
royalblues Thu, 06/12/2008 - 07:20
Did you configure something like
configure permit terminal
interface permit fastethernet
HAve a look at the attached doc for shell command auth configuration
emmawuxp06 Thu, 06/12/2008 - 07:42
yes, i missed the command - aaa authorization config-commands on the clients. After i added that, it works.
Thanks for your help
