Reports in Unity
Jun 12th, 2008
I have Unity UM 5.0 and when my customer want a report from the unity, the unity create the report but the url that have been sent return with page not found!
I have check the DNS ans it is ok.
Does somebody have a idea?
Zin.Karzazi Thu, 06/12/2008 - 06:07
Usually when you create reports using the admin page of unity, the reports are sent to an email address with a link, which can be accessed from anywhere using \\unity_IP\reports, can you access this directory from your explorer? could you please post the URL you are refering to?
f.gouger Thu, 06/12/2008 - 06:23
Thanks for your response, I did not explain the problem correctly. The email is received by the customer but when she tries to access the report, she received a page not found.
We are using Unity 5.0.
Jaime Valencia Thu, 06/12/2008 - 19:10
have you verified the reports are being generated?
if this helps, please rate
f.gouger Tue, 06/17/2008 - 11:28
Soory for the delay, I just verify and no the reports are not generate. When I enter the \\ip add\reports I do not find the reports.
Any idea?
