michelcaissie Thu, 06/12/2008 - 05:48
First specify the server address and name of config file with the command;
tftp-server inside [tftp IP] /[filename]
Then when you want to backup the config just do a " wr net "
abhadana Thu, 06/12/2008 - 06:29
a) To save the configuration on the TFTP server:
firewall(config)# tftp-server
firewall(config)# write net
For example:
firewall(config)# tftp-server inside 192.168.1.5 config.txt
b) To copy back the configuration to the ASA:
Before copying the configuration on the new ASA, set the same IP addresses of the
interfaces of the original ASA and also set the same TFTP server on the new ASA.
firewall(config)# config net :
For example:
Note: There must be a space between the word net and the colon (:)
