IPCC License question
Jun 12th, 2008
I recently upgraded from ipcc 4.0 to 5.x.
This is high availability. The license I was sent was not HA so when I tried to bring up second box I had an error. I now
have HA license. Do I have to remove the old license before I put the new one on? I have a license removal file but it is for 4.x. and I am not sure it is required. Any suggestions??
Art
Overall Rating: 4.5 (4 ratings)
gpulos Thu, 06/12/2008 - 09:40
  • Blue, 1500 points or more
You do not need to remove the first license.
You can install the new HA license and reset your CRS and you should be able to configure your HA.
Follow the license installation as I believe you have to reset CRS for the new license to take effect.
aelee1 Wed, 06/18/2008 - 16:10
Thank you for the input, I have not been able
to try the new license as it appears to be a few seats short. Once that is corrected I hope
to get it loaded. Thanks again
