06-12-2008 07:07 AM - edited 03-15-2019 11:14 AM
I have call manager 6.0 running on a publisher and subscriber. Things are generally working as advertised except for one problem with duplicate directory numbers (DNs).
The problem appears to come up when I get a request to move a DN from one site to another. The process I follow is:
1. add the DN to the requested phone
2. assign the DN on the new phone to the new partition
3. go back to the original phone and remove (dis-associate) the DN from it.
This process appears to create two DN instances in the database, one with the new partition, one with the old partition.
When I go back and clean up (delete) the orphaned DN I get and error (Unmapped Exception null) but the record appears to get deleted.
Has any body else seen this behavior?
Is there a different procedure I should be following to move DNs?
Is there a database maintenance procedure I should be running?
Solved! Go to Solution.
06-12-2008 09:21 AM
You may check CSCsk07400 and CSCsj95732 which are duplicated bugs you may upgrade to latest 6.1.2
06-12-2008 09:21 AM
06-12-2008 10:10 AM
That's not exactly the behavior I'm seeing but it's close enough to call it highly probable. Thanks for the help
