One way audio with FXS port under SCCP control
Jun 12th, 2008
  • Cisco Designated VIP,
    2017 IP Telephony
I just had an install where I used Vic4-fxs/did to integrate some polycom phones to ccm using sccp.
Howevr I am experiencing a one way voice on them.
I have searched the whole forum for similar problems, but havent found any such thing.
Any ideas will help
gogasca Thu, 06/12/2008 - 09:27
  • Green, 3000 points or more
Could you please paste your config
and make sure sccp binding routing is correct?
Are you using vic4 as sccp ?
using mgcp|h323 same issue
between which devices is the one way
