CCM6.1 Lab
Jun 12th, 2008
I currently have CCM6.1 setup in a lab using VMWARE. I have 2 phones setup and registered to Call Manager. I have 1 CSS and 1 Partition. Both phones are part of the CSS. The phone DN's are 5001 and 5002 and are assigned to the same partition. When I try dialing one of the phones, it will ring, but once I pick up, the dialing phone hears a Fast Busy. Here is an example. 5001 dials 5002. 5002 rings and picks up. 5001 will then hear a fast busy and 5002 will drop the call. This happens if I dial from 5002 to 5001 as well. Any insight?
Overall Rating: 5 (1 ratings)
Jaime Valencia Thu, 06/12/2008 - 08:37
  • Cisco Employee,
  • Hall of Fame,
    2011
sounds like call routing is set correctly due to the fact it rings, what codecs are you trying to use in the call??
javalenc
if this helps, please rate
d-roush Thu, 06/12/2008 - 09:25
Service Parameters have Intraregion codec for Audio set at G711/G722. I have the Region setup as using System Default for the Audio. Both Phones are in the same Device Pool as well.
Thanks.
d-roush Thu, 06/12/2008 - 10:46
I hard coded the codec in each region to use g711 for same region and g729 across regions and the call goes through perfect. I will have to research why it doesn't like the System Default settings. Thanks for the suggestion on where to look.
