UCM 6.1.2 & BAT
Jun 12th, 2008
Folks
we just installed ucm6.1.2, we are populating the database using BAT, however when I try to create the csv file it gives me the following error
"Object doesn't support this property or method" and highlight the Partition column, I'm putting in the partition column "Phones-CAC" for every single phone
what is wrong ?
Tommer Catlin Thu, 06/12/2008 - 08:24
Check the column header for Partition. Click on it and right after it is there a space? I found that on versions on CUCM 6.x, I would download the CSV, open in EXCEL make my changes, save as CSV and then try to upload... it would error out. Turns out after digging and digging, in one of my column headers in the there was a space after the name. So it shifted all column headers over one spot.
jeremy.rogers Fri, 06/20/2008 - 07:46
You said you are running 6.1(2)? If so, you are going to have to download the bat_6.1.2.1000(13).xlt file as they are version specific.
I am running into the same issue, but mine stops on my Line txt field. I have the correct BAT file and there are no spaces in mine either.
cris_jimenez Mon, 06/23/2008 - 08:26
I think its a problem with the macros and the BAt file for this version. I had to create a phone bat file and then a user bat file and then manually associate the users with the phones, a real pain in the ass
Tommer Catlin Mon, 06/23/2008 - 08:31
Yeah, I remember that also. I had to do the phones first, then the users. I could not have it create everything at once. Do not know why, but is how I had to get it to work also. Same for LDAP, but might be why. You have to put the phones in first, then sync LDAP, then associate users and phones. So a couple BAT files is mandatory with all new installs.
