CCM 4.1 Intercluster Trunk over site to site vpn
Answered Question
Jun 12th, 2008
How much bandwidth does an Intercluster (not intracluster) link need?
Can this work over a site to site vpn?
Will an intercluster trunk work if one cluster is running 4.1 and the other is running 6.1?
thanks in advance
Correct Answer by Kapil Atrish about 8 years 11 months ago
HI,
There is no replication between different clusters and no Keepalives. I've ICT working between different countries without any issue. The Trunk is a kind of hook created at one end to throw calls over to next party (i.e. next cluster). The only b/w required would be for calls.
thanks,
inner_silence
Correct Answer by gogasca about 8 years 11 months ago
yes it will work
for BW it will depend the codec u configure between ICT
G729 ~ 24 KB
G711 ~ 80 KB
Overall Rating: 5 (2 ratings)
Correct Answer
gogasca Thu, 06/12/2008 - 09:12
  • Green, 3000 points or more
yes it will work
G729 ~ 24 KB
G711 ~ 80 KB
SBCdd7343 Thu, 06/12/2008 - 12:33
Does the intercluster need X amount of dedicated bandwidth for it? Like is their a heartbeat that goes accross? What about any data repcliation?
Or only the amount of bandwidth for X amount of calls depending on the codec?
thanks
Correct Answer
Kapil Atrish Thu, 06/12/2008 - 15:54
HI,
thanks,
inner_silence
