06-12-2008 09:16 AM - edited 03-15-2019 11:14 AM
I have a 2851 with ios 12.4(h3) running MGCP. when someone calls the did 1531 they get a fast busy tone. the debugs shows the folliwing
FFHQVG01#
*Jun 12 16:45:40.729: ISDN Se0/0/0:23 Q931: RX <- SETUP pd = 8 callref = 0x1A54
Bearer Capability i = 0x8090A2
Standard = CCITT
Transfer Capability = Speech
Transfer Mode = Circuit
Transfer Rate = 64 kbit/s
Channel ID i = 0xA98381
Exclusive, Channel 1
Calling Party Number i = 0x4081, '9163387070'
Plan:Unknown, Type:Subscriber(local)
Called Party Number i = 0xC1, '1531'
Plan:ISDN, Type:Subscriber(local)
*Jun 12 16:45:40.757: ISDN Se0/0/0:23 Q931: TX -> CALL_PROC pd = 8 callref = 0x9A54
Channel ID i = 0xA98301
*Jun 12 16:45:40.757: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x9A54
Cause i = 0x80A9 - Temporary failure
*Jun 12 16:45:40.873: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x1A54
*Jun 12 16:45:40.889: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x9A54
*Jun 12 16:45:43.609: ISDN Se0/0/0:23 Q931: TX -> DISCONNECT pd = 8 callref = 0x046F
Cause i = 0x8090 - Normal call clearing
*Jun 12 16:45:43.873: ISDN Se0/0/0:23 Q931: RX <- RELEASE pd = 8 callref = 0x846F
*Jun 12 16:45:43.893: ISDN Se0/0/0:23 Q931: TX -> RELEASE_COMP pd = 8 callref = 0x046F
have you seen something like this before ?
we have 1000 DIDs and only 1 is giving the problem thank you
Solved! Go to Solution.
06-12-2008 04:50 PM
Oh ok looks like a change notification problem
COuld you please try to delete the DN and add it back if same issue can you restart ccm.exe ?
06-12-2008 09:24 AM
We use always the same channel?
What is 1531?
Cris could you pleas eupload CCM detailed trace for the failure?
06-12-2008 09:30 AM
06-12-2008 09:40 AM
06/12/2008 09:54:49.201 CCM|Digit analysis: match(pi="1", fqcn="", cn="9163387070",plv="4", pss="Lib-FF-911:Phones-CAC:Lib-FF-Centrex:Lib-FF-Local:Lib-FF-LD:Voicemail:MeetMe", dd="1531",dac="0")|<:SOLVOIPPUB-CLUSTER><:10.202.1.11><:2><:10.168.98.254><:>
06/12/2008 09:54:49.201 CCM|Digit analysis: analysis results|<:SOLVOIPPUB-CLUSTER><:10.202.1.11><:2><:10.168.98.254><:>
06/12/2008 09:54:49.201 CCM||PretransformCallingPartyNumber=9163387070
|DialingPartition=
|DialingPattern=
06/12/2008 09:54:49.217 CCM|Forwarding - initiateCFNA - CFNA to VM, callKey= 0x17C3E|<:SOLVOIPPUB-CLUSTER><:10.202.1.11><:2><:10.168.98.254><:>
06/12/2008 09:54:49.217 CCM|Forwarding - ERROR processCFToVM - both oCdpnVMPN and cdpnVMPN are NULL - clear the call, callKey= 0x17C3E|<:SOLVOIPPUB-CLUSTER><:10.202.1.11><:2><:10.168.98.254><:>
Which version of CCM?
Did you delete the DN recently ?
What is seen in the traces is that for this DN
is not in the DA table but in the intercepts
|InterceptPartition=Phones-CAC
|InterceptPattern=1531
Is that the correct info (partition)?
If CCM 4.1(3)sr5d or less an upgrade may be required for CSCsj30852 for long term fix or a CCM.exe restart for workaround
06-12-2008 09:47 AM
CCM version 4.0(2a)es64
I didn't delete the DN
the DN is on partition Phones-CAC that is the correct partition and I just double check and the DN is associated to 5 more phones.
06-12-2008 04:50 PM
06-12-2008 06:16 PM
that fixed the issue
thank you
06-13-2008 03:29 AM
Gonzalo,
What is "change notification problem"? How does deleting & recreating DN help here?
