AP (Aironet) authentication using ACS
Jun 12th, 2008
I have two requirement for AP using ACS,
Is the Pt#2 possible using ACS
<1>
I want administrator to modify any settings on AP using ACS authentication.
<2>
All users who wants to use AP for network connection should be authenticated using ACS. ( in ACS authentication is using Active-Directory )
Jagdeep Gambhir Fri, 06/13/2008 - 05:07
  • Red, 2250 points or more
Hi ,
There are two section in NAR"s.
Ist is IP based NAR
2nd is CLI/DNIS based
So for wireless users you need to apply only IP based NAR with condtion set to deny AP or NDG. By this wireless uses will NOT be able to ssh/telnet/http but they can connect to wireless network.
For admin users , no NAR would be configured. So that solve your issue
Check out this white paper,
http://www.cisco.com/en/US/products/sw/secursw/ps2086/products_white_paper09186a00801a8fd0.shtml
~JG
Do rate helpful posts
