Port Counter Errors
Jun 12th, 2008
In my Network is having 6509-E and 4006 on IOS and catos.couple of the interfaces/ports on Full Duplex with speed auto.
Pointing out the issue is with port counter errors facing ---> Alignment,FCS and Input errors are increasing the count.
how can i rectify this errors.
Thanks in advance!
Overall Rating: 4 (1 ratings)
kumarsri321 Thu, 06/12/2008 - 14:17
Thanks a lot!! Mark
Drill down the list?
might correct the errors
glen.grant Thu, 06/12/2008 - 13:04
  • Purple, 4500 points or more
Check on each end of the link on these , the settings must match , if the speed and duplex is auto on one end then it must be auto on the other end , if hardcoded to say 100/full then the other end must be hardcoded also . If you are attaching 2 cisco devices then auto/auto should work fine .
