Cisco 851W Problems
Jun 12th, 2008
I am having problems connecting some HTC smartphone devices to a CISCO 851W router. The devices receive the SSID but when we try to connect to the router they can't. The router works well for other devices (latops, PDAs) and the smartphones have worked well with a Linksys router, so the problem is specific to this the conncetion between this router and this devices.
Any help about this is welcomed.
Scott Fella Fri, 06/13/2008 - 14:02
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 Wireless
Can you post some of the logs on your 851W?
scottmac Sun, 06/15/2008 - 05:15
  • Green, 3000 points or more
What parameters are you using? (WEP / WPA {TKIP | AES}) etc ...
My 8525 didn't work well using AES. TKIP was OK.
It hardly worked at all with the factory / MS mobile drivers. I added Odyssey (now from Juniper ~US$35.00)and it connected nearly every time, and even worked with EAP-FAST.
Good Luck
Scott
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
