Add new E1 to old E1s to have same signal Channel .......???????????.......
Jun 12th, 2008
i need to add new E1 to be in the same trunk for previous E1 which is for Abdali. new E1 will not have signal it depeneds at old one.
i used this for new E1:
prov-add:nailedtrnk:name="1033",srcsvc="ss7p-jtc-abdali",dstsvc="naspath1-abdali",srcspan="ffff",dstspan="0",srctimeslot="33",dsttimeslot="33",spansize=31
for old one this:
prov-add:nailedtrnk:name="1002",srcsvc="ss7p-jtc-abdali",dstsvc="naspath1-abdali",srcspan="ffff",dstspan="0",srctimeslot="2",dsttimeslot="2",spansize=30
at AS5400 i used to add new E1:
controller E1 7/2
framing NO-CRC4
pri-group timeslots 1-31 nfas_d primary nfas_int 1 nfas_group 0
Is this true or there are other commands i should use?
OLD E1 is configured as:
controller E1 7/0
framing NO-CRC4
channel-group 0 timeslots 1
pri-group timeslots 2-31 nfas_d primary nfas_int 0 nfas_group 0
description Connection to Abdali
interface Serial7/0:0
no ip address
encapsulation ss7
channel-id 0
interface Serial7/0:15
no ip address
encapsulation hdlc
isdn switch-type primary-ni2c
isdn incoming-voice modem
isdn map address . plan isdn type network
isdn rlm-group 0
no isdn send-status-enquiry
isdn negotiate-bchan resend-setup
isdn bchan-number-order ascending
no cdp enable
please see attached file for more details.
any help please?
